Creo Parametric 3 should NOT need the CTRL key for the second selection in the Analysis Measure Dialog
The need for the CTRL button for multiple selections was introduced since Pro/E Wildfire.
The Use of the CTRL button has also influence on the 3D graphics manipulation.
As a result, the user must release the CTRL button when he wants for example rotate the view
and after the rotation, he must not forget to hit the CTRL button again, otherwise he loose previous
selections.
In general, the NEED of the CTRL button for multiple selections is contra productive especially
if the command is given upfront.
Frequent cases where the need of the CTRL button is annoying:
- second selection in the Analysis Measure dialog in Creo Parametric 3
- boundary surfaces selection in 'seed and boundaries' surface set
- edge selection for rounds if round command is already given.
- etc ...
2 Comments
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
