Creo Parametric - Save as a copy should propagate ptc_common_name from source object to new object.
Currently, Do save as (save a copy ) for Assembly/Part will not propagate ptc_common_name to new created object. File name will be propagated to new saved object as ptc_common_name instead of source ptc_common_name. At least, a new configuration option should be introduced to control this behavior.
2 Comments
TomU
This is probably similar enough to be considered a duplicate of Keep original Common Name during Save a Copy.
I do like the idea of a config option.  Maybe even make it smart enough where it will automatically change the name when it currently matches the file name otherwise leave it unchanged.
olivierlp
Community Manager
Status changed to: Archived
