Please add the ability to edit Model Feature Dimensions like points, rounds, curves, protrusions, etc. while in Creo Parametric Simulate.
There are many times when you have to go out of simulate to make adjustments to a model to address issues found while reviewing the results.
Having the ability to edit the model dimensions directly in Simulate would reduce the time to make designs more robust.
Don Anderson
