Creo Schematics needs a better sheet label function
For labeling zones on sheets, users are limited to three label functions using alphanumeric characters in Location Sets. Zones are labeled A, B, C, D, etc. We have the typical 4 zones per sheet. This works fine for sheets 1 through 6. Once you get to sheet 7, after the letter Z, it labels zones with special characters like [ and \. This is not very smart, especially given the way that highways label the cross sheet graphics in a pair of brackets. The cross sheet graphics can then look like [ [ , 2 ] which does not make sense to most people.
It would be better if the label function went to AA, BB, CC, DD, etc., or AA, AB, AC, AD, etc., after the letter Z. It would be even better if we could define our own label functions for Location Sets.
4 Comments
Dale_Rosema
22-Sapphire I
David Martin
You may want to vote on your own idea....
Thanks, Dale
dmartin
11-Garnet
Thanks. I always forget that for some reason the default is that you DON'T vote for the idea you proposed yourself.
Dale_Rosema
22-Sapphire I
I tried to get this fixed:
When creating a new product idea, it automatically adds a positive vote for the creator.
... but it is still under consideration....
PTCModerator
Emeritus
Status changed to: Under Consideration
