1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
I am Kamlesh and I am a Mechanical Engineer working as a technical support engineer in GMMSPL for PTC Creo
2. What version of Creo Parametric are you currently running?
Creo 8.0.5.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Dear Creo product manager and the team, today one of our customer had reported the issue in Creo sheetmetal as below
Sub:-Not able to create the miter cut for the below scenario
As you can see below image, it took almost 4 feature to create this behaviour, but if we have the miter cut kind of functionality for the individual edge in one go then it will save the huge time of the designer
I know the workaround is to use the flange command but some time it is not possible to use it.
4. What is the use case for your organization?
Increase the productivity and save time
5. What business value would your suggestion represent for your organization?
Creating more design within time
Kindly appreciate the idea.
