This is a 3 part product idea.
1. Add the ability to turn layers on and so one can hide construction surfaces so as to be able to select solid model geometry surfaces for Strain Vector Plots.
2. Add the ability to view vector strains only on the outer surfaces or surfaces in direct line of sight. (option to turn off vectors inside the part or on the other side of the part)
3. Add the ability to hide items selected in the selection window so one is able to select the base geometry for which results are needed more easily.
There are many times when you want to use Strain Vector Results in Creo Simulate to aid in placing strain gauges on physical product being tested.
Currently it very hard to view the strain vectors on the surface nearest to you that you are viewing.
Don Anderson
