Please give us the option to make Legend values persistent.
How many times have you worked on an assembly and wanted to Isolate a component so you can see the stresses, strain's, or displacement completely around the component only to have to re-enter the legend values again?
Please make this enhancement available for all analysis types and design studies.
Very annoying when you are trying to switch between different load cases for both a component or assembly.
Currently if you edit the results window definition the legend values rest to their defaults. Need the option to make the values we type in persistent (non-changing).
Verified not in Creo 2 & 3
Don Anderson
