The only way to view a transparent display of elements and nodes is to select results display types "Vectors" or "Model". There is no way of previewing a transparent mesh using AutoGEM or viewing a transparent but shaded fringe plot in results. If these capabilities could be added, the elements and nodes embedded within the material of components could be seen easily.
