Creo Simulation Live improvements ideas
Thirst thing I noticed is that forces and constraints are still visible even if before I stop simulation I switch it off.
I suggest: if simulation is stopped then in model tree it should be suppressed and loads should be hidden - don't you think?
There is nothing under RMB at the moment:
1 Comment
rsobecki
When I go to "Live Simulation Display Option" window toggle off both: legend and loads and also deactivate check box about show Min/Max then only WCS remain:
