Creo assembly - identify components that don't have matching units when adding
Creo should remember the units that the first default constraint item has eg. mm  and then when a component is being added Creo should flag up a message saying that this model is not the same units, do you want to change it? This would stop many problems including the datum planes going gigantic.
2 Comments
Dale_Rosema
Heather Hobson
You may want to vote on your own idea.....
olivierlp
Community Manager
Status changed to: Archived
