1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
I am Kamlesh and I am a Mechanical Engineer working as a technical support engineer in GMMSPL for PTC Creo
2. What version of Creo Parametric are you currently running?
Creo 9.0.1.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
In creo we have the scale model/part functionality and if possible we would like to have the scale option for the assembly file.
4. What is the use case for your organization?
For similar family of part, with this functionality we can explore result within time.
5. What business value would your suggestion represent for your organization?
Time-saving
