Reference Support Ticket #15518380
Reference SPR#11242864
We have noticed that if the Default assembly representations does not include a component, when a PVZ file is created, those components are missing without any way to view the master rep. There are 3 'Default' Viewables within this PVZ file and none of them show the master rep. However, from the Windchill cadworker, the generated viewable has one of these default Viewables be the master rep. Why? I would think there should be some consistency? Support says that this behavior has to do with the way the visualizations are generated. When being done manually, the master rep is not included. When done via a batch tool, like the cadworker, it is included. I would think that if there are 3 'Default' Viewables, then one should be the master rep (and named 'Master').
