Creo mechanism should be able to be created despite having another set disabled.
0 Kudos
You can't disable a set placing a part in an assembly and then create a mechanism connection but you can delete the set and create a new that is a mechanism connection? This fells very strange and should in my opinion be changed if it hasn't already in newer versions.
Using creo 2.0, M110.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
