Creo multibody
Creo multibody
Hello everyone,
If you like below thing that should be available in Creo Part modelling multibody
THERE SHOULD BE A WAY TO CREATE THE ASSEMBLY FROM MULTIBODY PART
Your reply is very valuable for me
4 Comments
If you want to use multibody part as a master model, this is a logical next step.
SC_5204572
Guest
this is most important aspect of design with multibody, it will save the time of reassemble the component created in the part environment.
I agree with the statement "THERE SHOULD BE A WAY TO CREATE THE ASSEMBLY FROM MULTIBODY PART".
I believe that you should be able to perform the assembly creation process more than once so that the assembly reflects the latest state of the multibody part from which the assembly is made.
kamleshjoshi
Amethyst
Yes
