Creo to be capable of intelligently importing a PDF file
It would be beneficial to us if we could take in a PDF file as a Legacy file and have the import result in 'converted to editable' lines and text format. Ideally in the same way as www.scan2cad.com/ suggests is quite easily possible. An intelligent approach to re-interpreting a PDF may prove to be an easier proposition than trying to deal with all the variables involved in the export/import process of 2D from legacy 2D/3D CAD systems.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
