Crosshatching from Material
It would be nice if the system would automatically assign the proper material crosshatch as defined by ASME to the model when the material is assigned. When a cross section is then applied to the model, the proper section lining will be automatically applied. The section lining could be an added line to the material file that Creo would read.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
