Custom gear
Custom gear
Hi all,
It would be fine having the possibility of making a "custom gear" in the sense that at the moment I can constrain two motion axis in a reciprocal movement only as a gear (so tipically a constant value).
What I have in mind is to introduce the possibility of "write" the law that constrain x1/theta1 to x2/theta2.
In that condition you can easily simulate intermittent mechanisms (like globoidal cams) that can't have the "cam's constraint" because the surfaces doesen't allow you and you need to pun another servo motor on the cam's axis.
Bye
2 Comments
Fraulini_Giulio
6-Contributor
Nobody thinks that an improvement in mechanism is necessary?
olivierlp
Community Manager
Status changed to: Archived
