In 2D drawings and prints, line thickness and weight can be modified through the pen_line_weight and pen_line_thickness config settings. I think it may be a good idea to add a config setting for the thickness of 3D dimension lines and 3D leader lines. Another option may be to define the line thickness in the Text Styles settings in the Dimension Properties.
