DXF import on PART
DXF import on PART
When we create a Drawnig with DXF,
In a message box, we can set the colors of the curves
If we import dxf in part, we do not have this dialog box to easily change the colors of curves.
We must select the curves to change their properties (if there are a lot entity, it is not easy and very long) :
Workarounds:
  • Search Tool Workaround:
    1. Click the Search Tool icon
    2. Select 3D Curves as Look for and Look by
    3. Select All under History tab
    4. Click Find Now and
    5. Select the desired curves
    6. Close Search Tool Window
    7. RMB in the graphics area and select Properties
  • Box Selection Workaround:
    1. Edit Definition of the Import Feature
    2. Click Import Data Doctor (IDD) icon
    3. Select Curves in the Smart Filter
    4. Drag a selection box around the desired curves
    5. RMB in the graphics area and select Properties
Is it possible to have this dialog box when importing DXF, STEP ... ?
1 Comment
olivierlp
Community Manager
Status changed to: Archived
