Default Draft Check Should be 3 Colors
Revise the default color scheme for draft checks to be 3 colors.  Assuming the user is checking for X degrees of draft, all surfaces should display in one of 3 colors:
  • One color (Blue?) for draft greater than +X
  • One color (Magenta?) for draft less than -X
  • One colr (Yellow?) for draft between +X and -X.
3 Comments
DeanLong
Reasonable request. But should still have the ability to to see the rainbow (I.E. color spectrum)
dgschaefer
Absolutely, need to be able to tweak as desired but the default ought to be to make the P/L obvious and undrafted areas obvious.
PTCModerator
Emeritus
Status changed to: Archived
