In Assembly mode we can configure the default behavior for failed assembly components (ALLOW_FREEZE_FAILED_ASSY_COMP).
Add similar configuration option to choose default behavior (Delete or Suspend) for children handling in Part Mode.
Thats a good ideia!
It hapens to me allot, and if i can change it, to suspend by default, it It would make my job easier.
I support this request, this could easily by integrated as an option for default behavior.
It's been posted 5years ago, I'm surprised it didn't get more votes.
I would also like a similar default configuration option for children in assemblies.
Now the default behaviour is to delete/suppress all parts/assemblies constrained to the one being deleted/suppressed.
This would drastically improve my life when fixing broken model trees! Please add.
At least add a box/button to say select all, and then choose suspend for everything.
Creo tip: You can press Ctrl+A (old school select all) to select all then RMB and select suspend.
