Security Alert Log4j Security Vulnerability. Click here to know more.
Default options when Generating Report in Model Manager should be configurable
In the BOM Editor in Model Manager you can generate a report.
The different options are always the default values.
It should be configurable to change the default values, cause now you always have to change them again.
OK, you can store a Report Configuration, but the number of clicks to select a Report Configuration is as many as changing these options every time.
Other option is to make the Report Configuration selection available directly in the BOM Editor UI.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
