For the moment, if you use a drawing template, you can't select the default simplified representation.
The only two possibilities are:
- Create a view in the drawing template --> not very useful if you want use the template for lot of different drawings
- Add the model in a empty DRW to select the good representation --> no drawing template
It would be nice if we can simply define a default simplified representation for a drawing template !
