The first sketch is never at the right scale of your usual models.
Personally, the skeches are systematically 30 times larger than the scale of our models.
A circle measures 600 (mm) by default – we need to sketch at 20 (mm).
A config.pro option would be very nice to define the default sketch size.
default_sketch_size 20 (for example).
We shouldn’t need to use the “lock scale” to bring down the dimensions to our usual model scale.
