With tool design for designing a mold,
there's a limited undo functionality in the sub-tab "parting surface",
if a sketch is made, there is also no way to delete it until the command is canceled, which can result in a loss of effort (the good sketches are lost as well if you cancel the parting surface command).
I'd like to see the general functionality inside the parting surface command working just like the rest of creo , adding sketches and deleting them should be no problem.
