When deleting the base line for ordinate dimensions, a message will appear (see picture below) saying that the dependent dimensions will be deleted as well. On some drawings there are several such baselines, on one axis. Now I can not find which dimensions are affected, which are dependent and which are deleted? (no dimensions are highlighted)
I'm sure I'm not the only one in the world who would.
It just gets stupid when measurements are shifted to other sheets.
If a measurement is accidentally deleted it can have fatal consequences for the part quality. Up to the failure of transmissions, axles, engines, steering systems, airplanes....
Please show the dependent dimensions, from the base line of an ordinate dimension
