The great Advantage of DEX is to save different configurations of models from same version in Windchill. Unfortunately it's not possible to open drawings in a DEX session. It would be a big advantage if drawings would be included in a DEX session. In general you need drawings for documentation of the different versions. In our case we use a drawing for configuration of the model.
At least, I don't understand this limitation.
