Detail View Note Spacing
Current Detail View notes create "DETAIL__X", "SCALE__XX". Users must manually remove the double spacing between detail and letter callout in the view note for every view. Please allow this to be globally set to remove the double spacing.
3 Comments
StephenW
23-Emerald II
This is a duplicate: Vote on this one:
https://community.ptc.com/t5/Creo-Parametric-Ideas/Properly-represent-ASME-Detail-View-note/idi-p/45...
<Community Moderator edit:  The idea ( from 2012) referenced above has been archived because it was not included in the 2019 Community Ideas Program so the community is unable to vote on this previous idea.  Community should vote for this one bquartier to give it more visibility.>
Also, someone created a mapkey here: (possibly is does more formating,but a mapkey would reduce the edit time)
https://community.ptc.com/t5/Creo-Modeling-Questions/Related-notes/m-p/68602/highlight/true#M17535
BenLoosli
23-Emerald I
I see no ASME standard that requires a single space only between the view type and the view callout. The double space does provide some clarity between the view name and the view callout so it doesn't look run together.
According to the duplicate referenced by Stephen, that thread has been closed and marked Archived by PTC. It should have been fixed back in Creo 2.
I am on Creo 4 m080 and I still see the double spaces.
Always state the version and build of your problem, as it may have been fixed in a later release.
bquartier
7-Bedrock
According to the duplicate referenced by Stephen, that thread has been closed and marked Archived by PTC. It should have been fixed back in Creo 2. I am on Creo 4 m080 and I still see the double spaces.
Yes, I tried to find any ASME guidelines on this, and found none, but neither does it say a double space shall be there either. We are on Creo 4 M060.
I did do a search before I posted and found the same as your link above, but since you cannot vote on archived ideas I created this one. A mapkey would work, but that's a work around. It's really not that difficult to simply remove the space manually, but as it is wasting time for users I would prefer to have the option to set the format through drawing option, similar to detail_circle_note_text.
