The color of dimensions with missing references in the drawing is very confusing in the Creo 4 default theme.
* In Creo2's default theme and Creo4's light/dark theme, it is clearly distinguishable.
* In Creo7 and Creo8, it is also difficult to distinguish the reference disappearance dimension in the default theme.
I check the reference vanishing dimension by changing to the "light color theme" or "dark color theme", but I would like to see improvements so that it is easy to distinguish even with the default theme.
