Could you add an additional enhancement in the config.pro options to customize this behavior?
Currently the option to use the double click behavior involves:
- Driving dimensions automatically go to value edit
- All other dimensions will display the dialog box.
So is it possible to turn the customize double click behavior to turn edit on or off.
In other words when double click on model dimension we should be able to see dimension property box not edit.
