This would fix a few dimension issues that have popped up with Creo 2.
- Add a button, a 3rd step to ‘flip text’. The 3rd step would flip it to the middle, so you have the choice or ‘left’ right’ and ‘middle’. And, while we’re at it, put back the functionality to grab & move the text around like we once did.
- Ordinate dimensioning; make it so when you add a jog, you can still move the dim up & down, left & right. Now, once you add a jog to the leader line of an ordinate dim, you can then only move it in the plane in which it was set. (you used to do it in WF5)
