Security Alert Log4j Security Vulnerability. Click here to know more.
Direct Licensing Configuration Client
Why needs the start of "Creo Elements/Direct Licensing Configuration Client" needs
long time depening on ports enabled in Creo Elements/Direct Drafting 18.1?
  • Starting the Licensing Configuration Client with only 1 LAN Adapter needs 8seconds
  • Starting it with LAN und Bluetooth Adapter needs 12seconds
  • Starting it with 2x LAN und Bluetooth Adapter needs 15seconds
  • On a notebook having LAN, WLAN, Bluetooth needs the start 1:00minute.
What is the reason that the start needs sometimes such a long time?
3 Comments
thollerweger
The problem is caused by the big amount of COM Ports when bluetooth is on. Each COM port is asked for a security device with a large timout period.
It makes no difference, if the device is activated or deactivated.
I would suggest that COM Ports shoul not be asked for security devices because it makes no sense to bind a portable license to a dongle connected to a com port. Binding the license to a network device is the only meaningful way.
lfortner
9-Granite
Let have a look at %ALLUSERSPROFILE%\PTC\Licensing\Application (W7). You may delete the MECLCONF.conf file (it will be rebuild automatically).
If you're curious, let have a look to the MECLCONF.conf content.
PTCModerator
Emeritus
Status changed to: Archived
