The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Disable Automatic regeneration of model
It would be interesting to have an option to disable automatic regeneration of model. This would save time as a result of several modifications to the assembly components or to the model.
4 Comments
rsobecki
is your idea about having ability to influence at separate part or group to set status for no automatic regeneration until user will allow on that?
could you be so kind and explain this idea base on some example description - please...
BenLoosli
23-Emerald II
Please explain in more detail what issue you are trying to solve?
Creo is a history  based modeller and needs to have prior features resolved before it can work on other features.
ggalli
6-Contributor
It would be interesting if I could choice when regenerating a assembly. This would save time as a result of several modifications to the assembly components because  I could regenerate only 1 time.
olivierlp
Community Manager
Status changed to: Archived
