I want to exclude components in simp. representation based on their storage folders in Windchill ==> I decide to create a simplified representation based on rules
When creating the simplified rep. based on rules in Creo Parametric, for exemple a rule that exclude component based on the parameter PTC_WM_LOCATION( attribute=> Expression => string => PTC_WM_LOCATION => égal) ==> the expression value field is limited to 32 caracters !
This is very annoying, as this parameter gives the location of the subfolder in a Windchill Context, i want to take just a portion of the entier expression, when selecting the value of the expression from the drop down menu, it allows the expression to be very long, when typing Anything manually it takes you back to the 32 caracters limitation.
I think this limitation is not logical and should be removed.
Thanks in advance.
