Disable "Custom Check In" in Model Tree-Menu via Toolkit (Pro/E 5.0)
Background:
User has checked in the viewabels of his PRT/ASM via Custom Check In -> Viewbales.
Result: no content send to PDMLink.
User deleted his local cache.
Result: Content lost.
Now, the customer wants to disable this functionality (Check in only Viewables).
There are two ways to check in the viewables:
1. File -> Check In -> Custom Check In -> Viewables.
To disable this functionality this menu can be edited via "Customize Screen ..."
2. In the Model Tree -> Right mous -> Custom Check In -> Viewbales.
This menu can not be customized via the "Customize Screen..." or "Toolkit". There is no way to customize this menu.
Expected: customizing this menu through Toolkit.
Related PTC Case:
https://www.ptc.com/appserver/cs/view/case.jsp?n=10630234 (German)
https://www.ptc.com/appserver/cs/view/case.jsp?n=10733572
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
