Display View Style Configurations in Drawing Views
Allow the use of view style configurations in drawing views to allow mixed display styles on a drawing
Example of use:  an assembly drawing of an LCD bonded to a piece of clear glass viewed from the glass side
In this case, the glass has ink sillkscreened on the side of the glass bonded to the LCD, represented as a hatched curve feature
Desired result is a front view of the assembly with the glass represented in wireframe that allows the silkscreen and LCD to be visible as no-hidden
Currently it is not possble to change the component display of the glass to show the components behind AND represent the edges as solid geometry lines
1 Comment
olivierlp
Community Manager
Status changed to: Archived
