If the file is missing which INPUT should load the meaningless error message appears: <Enter 'input_filename'> or <Dateiname fÏr input eingeben.>
It's often hard to find the file in which the INPUT function is called. In most cases ME10 must be restarted with TRACEing to file.
To display the filename of INPUT-file which cannot be load by INPUT will save much time programmers must use for searching and tracing macros.
PS: This should have been integrated in ME10 Version 4.31
