When creating drawings, the line thickness should be shown.For example:Visible edges thickDimensions thin
In addition, the Invisible Lines should be displayed as dashed lines and not as solid lines in a different color as is currently the case.
sehr gut
Dimensions thin
Just saying that if you think by creating 100's of ID's and voting up a topic, that will make something happen...
I would say you are wasting a lot of time, but it's your time to waste.🤣
I posted similar idea in 2016. Still nothing had happen in this area.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Geometry-on-a-drawing-in-real-thickness/idi-p/457...
