When working in Creo I often have a "master part" with many surfaces which is best viewed with the 'wireframe' display style. However all of my other open windows with parts and assemblies are best viewed "shaded with edges". As I switch between the open windows I have to keep manually changing the 'display style'. It would be extremely nice if each window's display style remained set independently of how the other windows are set. A config option / setting to modify this behavior would also be a nice feature.
