Displaying Dimensions from Table Patterns
If a table pattern is used for modeling, the dimensions cannot be displayed in a drawing.
This means that there is no possibility to use the parametrics in the drawing. One of the main advantages, the modification of a model via the drawing is therefore simply not feasible.
It must therefore be possible to display all dimensions from table patterns in drawings.
Below is an example with such a table pattern. The dimensions that cannot be displayed are entered in the drawing and marked with "???". The second picture shows the table with the entered values.
2 Comments
mwimberly
6-Contributor
I was just posting the same thing.  I have a hole that I have patterned and I want to modify the location of them outside of the table but I can't.  I added a the hole diameter as an additional dimension and I can change that for each hole but none of the location dimensions are displayed.  This should be possible and I am not sure why it is not.  I agree that this defeats the purpose of having everything parametric if I am forced to create dimensions for anything in a pattern table.
olivierlp
Community Manager
Status changed to: Archived
