We have the below config set:
def_layer LAYER_QUILT 6_ALL_SURFS
When importing a model, it automatically assigns all quilts/surfaces to that layer, whether the feature was solidified or not. When you enter the Import Data Doctor (IDD) and the layer is hidden, the components are gone from the graphic window, but even worse - they don't show in the IDD GTS Tree either. I go from seeing a solid to seeing nothing when doing the EDIT DEFINITION. We should at least see the feature and show that it is hidden.
