in Drafting. user can add the dimension with the tolerance.
but in Creo there is check box to display tolerance upper limit and lower limit.
but there is no API in creo toolkit to know whether that tolerance upper limit and lower limit is visible or not.
please plan to add an API to get the tolerance upper limit and lower limit is visible or not in drawing.
Vipresh shah
