Drawing Mode: Allow both horizontal & vertical view alignments to be active together
In drawing mode I would like to have the ability to use both horizontal and vertical view alignment at the same time. Currently I can apply one alignment then the next, which ever is applied last will be the rule that applies. When the parent view is moved the last alignment applies and I have to go back into the view properties to realign the other direction. This wastes time. Please vote this up.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
