Drawing Sheet Publish Option
In Creo 4, PTC included a Publish option for 3D View States so users could have views that wouldn't have to publish to Creo View. This same functionality would be very useful for Drawing Sheets. I could see several use cases from this: having a DXF sheet that won't publish to PDF or maybe having a secondary page for engineering notes. Our CAD designers end up having to do a lot of monkeying around to prevent DXF sheets from messing up drawing PDF's (they create a whole new PDM object called DrawingName_dxf.drw or create DXF's drawing on the fly with mapkeys).The non published sheet would not be included the total number of sheets, every sheet would publish by default, and there'd be a way to transfer this to CAD Workers that auto publish PDFs.
Here's the option shown in Creo 4 for View States:
5 Comments
Dale_Rosema
22-Sapphire I
Especially dxf of sheetmetal or laser cut parts that need to go to the vendor.
RandyJones
We have our publishing setup to create the "standard" Creo View hpgl plus a pdf and a dxf via publish rules for all drawings. It would be nice to have options to control which sheets were published to which formats. For example:
Sheet 1: all formats
Sheet 2: hpgl, pdf only
Sheet 3: dxf only
RandyJones
Sheet 3: dxf only
What I meant by "options to control" would be controlled by detailer setting these options in the drawing for each sheet that needed special publishing handling.
dgarcia
9-Granite
Exactly
tm-4
8-Gravel
Yes I accept.
When a DXF file is created from a sheet in the drawing this sheet need to be removed prior to generating the PDF output file. This option need to be handled in some parameter.
