Drawing Table Format
When you add a column/row to an existing table, the text style should match that of the other columns/rows.
8 Comments
mdebower
18-Opal
GREAT IDEA!!
lpitts-2
2-Guest
It's sad that after this many years we even have to bring this up and waste time voting on it.
pbarnett-2
1-Newbie
If this was the only issue with Creo or Pro/E I would be happy found so many problems with it I have had to knuckle down and bare it, For the formatting tables I have created a map key that fixes it you highlight the row/cell and mapkey sorts out formatting
dgrobe
6-Contributor
i deleted my idea since i found this one.. nothing worse than this..  however.. i think when adding a row inside the table.. it follows the format..  but adding a row at the bottom.. does not..
ghodge
1-Newbie
Yes the text in the table should match that of the existing rows. Just more proof of how sad of a drafting package PTC has
PTCModerator
Emeritus
Mfridman
Status changed to: Under Consideration
BenLoosli
22-Sapphire III
How do you handle different formatting?
I use a larger font on my header rows than on the data rows.
I also use some columns centered and some left justified.
This would need some guidelines in the documentation about where the added row/column was picking up its formatting from.
