Drawing Table Parameters to create a Table-of-Contents
Drawings with multiple sheets need a Table of Contents (TOC) - just like any other multi-page document.   Report repeat region parameters would need to be established for just this purpose.  A Table of Contents should be just as easy to implement as a Bill of Materials.  A parametric Table of Contents would update any time a sheet is added, or is re-named or moved in sequence.
2 Comments
BenLoosli
PTC would need to add sheet dependent variables that could be used for the repeat region so you can have individual sheet descriptions in the title block.
Need a method of adding parameters for each sheet to drive the descriptions.
Currently, we use the same descriptions on all sheets of a multi-sheet drawing.
Aaron_Daniel
There is already a sheet dependent variable called "sheet_name".  Seems to me it shouldn't be too difficult to add other sheet dependent parameters (such as 'sheet_description', 'sheet_status', 'sheet_model', etc.), perhaps by right-clicking on the sheet tab at the bottom of the detailing window and selecting a new option to 'Edit Sheet Parameters'.
