Drawings with multiple sheets need a Table of Contents (TOC) - just like any other multi-page document. Report repeat region parameters would need to be established for just this purpose. A Table of Contents should be just as easy to implement as a Bill of Materials. A parametric Table of Contents would update any time a sheet is added, or is re-named or moved in sequence.
