Drawing View Arrows for more views
Drawing View Arrows are available for cross sections, projections, and auxiliary views.
A nice addition would be the ability to create view arrows to unrelated views on multiple pages.
One example we've encountered are general views that are created on a separate page.
You shouldn't always have to do a projection or auxiliary view on same sheet as the parent view and then move it to the appropriate sheet to keep view arrows. View arrows are often more important on multiple sheet drawings than on the same sheet.
When switching a view from general to projection/auxiliary you cannot switch sheets to select a different view.
Cross section arrows also cannot be put onto a different page directly.
2 Comments
Amethyst
hello,
For information, If you use the floating menu > Add arrows you can select views in other sheets.
Community Manager
Status changed to: Archived
