Drawings Flip Text in Dimensions Multiple Selection Option
0 Kudos
This video demonstrates how text in a dimension is flipped to the other side of the dimension in Creo 4.0. This is a manual, single dimension action that has to be repeated for each dimension this is required on. The ability to select multiple dimensions and flip the text would improve the ease and speed when this is required in a drawing with many dimensions. In early versions we could select right before the text and drag it to the other side. This would be a great enhancement to the Flip Text option.
3 Comments
WayneSchrock
In Creo 4.0 M040, you can select multiple dimension (if needed) and move the text to other side. You must use your shift key to move the text.
Hope this helps.
Wayne
ptc-376588
3-Visitor
Wayne
Excellent News, I just tried it and it works. I was working with a support tech on a different issue and he mentioned I post this as an idea as he had no clue how to make this happen.
Mfridman
Status changed to: Current Functionality
Hi all,
As mentioned correctly earlier by @WayneSchrock , you can select multiple dimensions, hold the "shift" key and drag the selected dimensions to the other side.
Converting this product idea to "Current Functionality"
