Need to constraint or fix the distance between two view..
For Example : Please find below snapshot for reference
I had modeled a shaft of 100 Dia and 1000 mm length and placed same in drawing with scale factor of 0.15
but when i reduced it size to 100 mm length views get merged.
My concern is that views should maintain some specified horizontal distance between them and should not get merged.
